最終更新
2025年2月5日
読書時間
4分で読める
共有
この記事では
D5 Render地形ツールで建築造園を極める
Designing landscapes and terrains in 3D has always required a mix of creativity and technical know-how. With D5 Render’s 2.9 update, however, the process has become simpler, faster, and more intuitive. Whether you’re an experienced 3D artist or exploring the world of landscape architecture, D5 Render offers a robust set of tools to bring your vision to life.
Previously, creating terrain involved external software like SketchUp or Blender. Now, D5 allows you to sculpt, paint, and customize terrain directly within the platform. This 2.9 update not only saves time but also enhances creativity by providing tools like 3D stamps, built-in textures, and dynamic vegetation.
Step 1: Sculpting Terrain
The highlight of the 2.9 update is the ability to sculpt terrain directly in D5 Render. Here’s how it works:
  • Start with a Terrain Plane: Unlike earlier versions, your scene now starts with a terrain plane instead of a flat gray bottom.
  • Sculpting Tools: Use the brush tool to raise or lower terrain, create plateaus, or smooth out areas. For example, you can add hills to your scene by simply dragging and adjusting the brush strength.
  • Heightmap Resources: Add predefined terrain features like hills and mounds with just a click. These elements are fully editable, blending seamlessly into your landscape.
By using these tools, you can design terrains that feel natural and visually compelling without needing external modeling software.
Step 2: Painting and Texturing
D5 Render makes painting and texturing terrains incredibly straightforward:
  • Select Your Palette: Choose from a wide range of textures, including gravel, paths, snow, and grass. These can be applied directly to the terrain using the paint tool.
  • Customize Peaks and Slopes: Adjust the appearance of mountains and slopes to create unique looks. For instance, you can blend snowy peaks with rocky slopes for a dynamic effect.
  • Full Scene Presets: Quickly transform your terrain with pre-configured settings for forests, deserts, or snowy landscapes.
This step brings color and character to your terrain, setting the stage for further detailing.
Step 3: Populating the Scene with Trees and Shrubs
Once your terrain is ready, it’s time to populate it with vegetation:
  • Explore the Asset Library: D5’s library includes over 3,600 nature assets, such as trees, shrubs, and flowers. Search for specific plants using their scientific names for precise selection.
  • Scatter Functionality: Automatically distribute assets across your terrain. Adjust the density and scaling to create natural-looking forests or gardens.
  • Dynamic Vegetation: Select models that respond to wind and environmental settings, adding a touch of realism to your scene.
For example, you can create an autumn forest by scattering trees with vibrant orange, yellow, and green leaves.
Step 4: Camera and Lighting Setup
Once your landscape is built, it’s time to showcase it with the perfect composition:
  • Position Your Camera: Experiment with angles, focal lengths, and depth of field to highlight key features.
  • Enhance Lighting: Use dynamic or static lighting to set the mood. Add fog for atmospheric depth or adjust bloom and exposure for a stylized effect.
  • FPS Booster: This new feature improves performance, ensuring smooth navigation even in scenes with millions of faces.
Careful camera and lighting choices will bring out the best in your design.
Step 5: Rendering and Animation
The final step is to render your scene or create animations:
  • Rendering Options: Export images in your desired resolution. Try different angles or explore variations like snowy landscapes for diverse outputs.
  • Camera Path Animations: Define paths between keyframes for smooth transitions. This is ideal for presentations or walkthroughs.
Add volumetrics, adjust scatter settings, or refine textures to achieve a polished result.
Conclusion: Bring Your Vision to Life with D5 Render
With the 2.9 update, D5 Render makes creating landscapes and terrains easier than ever. From intuitive sculpting tools to dynamic vegetation, it gives you everything you need to turn your ideas into stunning 3D visuals. Whether you’re working on architecture, animation, or personal projects, D5 helps you achieve professional-quality results with ease.
Ready to transform your designs? Explore D5 Render today and bring your landscapes to life!
こちらもおすすめ
お問い合わせ:contact@d5techs.com
マーケティング:marketing@d5techs.com
テクニカルサポート:support@d5techs.com
