DERNIÈRE MISE À JOUR
5 mars 2026
Temps de lecture
13 min de lecture
PARTAGER
DANS CET ARTICLE
D5 Render 3.0 est en ligne : Une nouvelle ère de rendu par l'IA pour votre flux de travail de conception
Visualization shouldn’t be a fight against your tools. Yet, for too long, we’ve been stuck in a cycle of exporting and waiting that forces you to manage software instead of designing spaces. It’s an interruptive loop that breaks your creative momentum.
Today, we’re replacing that loop with a connected ‘Flow State’. Enter the New D5 Workflow—an all-in-one ecosystem uniting the real-time concept exploration of D5 Lite, the curated resources of D5 Works, and the powerhouse performance of D5 Render 3.0.
As the intelligent core of the new D5 Workflow, D5 Render 3.0 delivers our most substantial capability leap to date. It now integrates a comprehensive suite of 15+ built-in AI features with critical refinements to the existing tools you rely on daily. Whether crafting complex visualizations or rapid design iterations, this release is engineered to keep you productive. Let’s dive into the highlights.
At a Glance: Why D5 Render 3.0 Changes Everything
  • BonjourA Unified Creative Flow: Say goodbye to fragmented tools; our new ecosystem keeps your flux de conception seamless from the first concept to the final, polished frame.Bonjour
  • AI-Powered Creativity: D5 Render now hosts a robust suite of 15+ AI features, including AI Scene Match, designed to eliminate the manual grind of scene setting.Bonjour
  • Instant Environmental Realism: Crafting dynamic oceans and volumetric clouds is now procedural, allowing you to build living, breathing worlds in a few clicks.Bonjour
  • Direct Asset Access: With D5 Works integrated right into the launcher, you can source and manage premium, AEC-ready resources without breaking your momentum.
1. D5 Lite: Where Every Great Design Begins
To understand how D5 Render 3.0 transforms your speed, we have to look at where the “Flow State” begins. The true power of the D5 all-in-one workflow is that it doesn’t wait for your model to be finished; it starts the moment you have an idea. D5 Lite serves as the essential bridge between initial conceptualization and design development, living directly within your SketchUp viewport to blend Generative AI with real-time feedback.
By offering professional rendering powered by our in-house D5 Engine, D5 Lite allows you to experiment with light, mood, and massing in seconds—effectively curing “setup fatigue.” It creates a creative playground where you can pivot freely without the weight of wasted hours. Once your concept is locked, transitioning into the powerhouse performance of D5 Render 3.0 is a natural evolution, not a restart.
D5 Lite: Model-driven AI references featuring optimized presets across diverse design scenarios.
2. Automating Your 3D Design Workflow with AI
AI Agent: AI Scene Match
Setting the right mood shouldn’t take hours of trial and error. Now, simply describe your desired atmosphere—’Autumn dusk’ or ‘Snowy winter’—and D5’s AI Agent will generate reference visuals. Then with a single click, it matches the lighting and post-processing parameters to your scene instantly.
AI Agent: AI Asset Recommendaton
Eliminate the fatigue of digging through thousands of assets. Whether you upload a reference image or type a prompt like “coniferous trees for aerial view,” D5 3.0’s AI Agent intelligently suggests the perfect models from the library to populate your scene, keeping you in the flow.
AI Asset Recommendation in D5 Render: Reference-based asset curation and intelligent spatial locating
AI Image to 3D
Need a specific asset that isn’t in the library? Simply upload a reference photo. Our new AI generative tool will analyze the image and build a high-accuracy 3D model for you in seconds.
AI Image to 3D in D5 Render: High-fidelity model reconstruction via AI-driven structural inference
Optimizations
We’ve also fine-tuned the AI tools you rely on daily. The AI PBR Material Snap now offers enhanced matching accuracy and greater variation in results, ensuring textures align perfectly with your references. Meanwhile, the Optimized AI Enhancer delivers sharper image definition with refined logic specifically tailored for interior projects.
3. Instant Realism: Ocean, City, and Atmosphere
Achieving true realism often means fighting with complex geometry. We’ve automated that struggle, delivering physically accurate environments, you can build living worlds without the manual grind.
The New Ocean System
Crafting realistic water used to be labor-intensive. Now, you can deploy vast, dynamic oceans with a single click. The system intuitively analyzes your terrain to generate organic coastline transitions, rolling waves, and wet-sand effects. It’s not just a plane; it’s a living environment.
Océan en D5 Render: Vagues dynamiques, caustiques et interactions réalistes avec le littoral
True Displacement Material
We’ve introduced the Matériau de déplacement (bêta) to complement our existing Parallax solution. By physically displacing geometry based on height maps, D5 creates true-to-life depth. It’s a game-changer for close-ups of textured materials like masonry, stone, and woven fabrics.
Displacement Material en D5 Render: Profondeur de surface plus vraie que nature grâce à la modification géométrique en temps réel
Volumetric Clouds & Fog
We’ve completely overhauled the weather system. With the all-new Volumetric Cloud, we are moving beyond simple backgrounds to hyper-realistic depth and flexible visual control. This update empowers you to freely sculpt the sky—starting with accurate presets like Cumulus or Stratocumulus, then fine-tuning density and altitude to match your exact artistic vision.
To complete the atmosphere, the updated Fog system now offers independent color and density controls. It also features a new ‘Follow Sunlight’ option that ensures natural depth and realistic light scattering, regardless of the time of day.
Volumetric Clouds (Presets) in D5 Render: Instant, versatile atmospheric cloudscapes
Procedural Building in City Generator
Just as the Ocean system brings life to the coast, our enhanced City Generator now incorporates Procedural Building capabilities to rapidly populate urban backdrops. By simply enabling the “Styles” option, you can generate stylized appearances for your buildings instantly—allowing you to create rich, dense city contexts that frame your design.
Procedural Building in D5 City Generator: Auto-generate stylized appereances of architecture
4. D5 Works: Your Premier Creative Hub
Le new D5 Workflow isn’t just about rendering; it’s about fluidity. We’ve removed the friction between inspiration and creation by integrating D5 Works directly into the launcher, placing a comprehensive resource library right at your fingertips.
Think of this as your dedicated creative marketplace, curated specifically for AEC professionals.
  • BonjourAEC-Ready Resources: Access a vast library of professional-grade assets—making high-end design accessible to everyone. From detailed furniture to complete scenes, everything is prepared to fit instantly into your projects.Bonjour
  • Streamlined Management: Stop hunting for scattered files. You can now source, organize, and download premium assets directly from the interface, mirroring the intuitive experience of the native D5 Asset Library.Bonjour
  • Affordable Assets: Leverage D5 Works for top-tier resources at accessible rates—delivering high-end results without the overhead.
Quick access to the D5 Works (a hub for professional-grade assets) directly via the Lanceur D5
5. Fluid Navigation: Move the Way You Think
D5 Render 3.0 introduces Free Mode, a unified navigation system that blends the best of “Walk” and “Fly” modes into one intuitive experience.
  • BonjourSeamless Control: Move through your scene with fluid keyboard and mouse combinations. Whether you’re inspecting a detail or flying over a master plan, the transition is effortless.Bonjour
  • Muscle-Memory Friendly: Transitioning from SketchUp, Rhino, or 3ds Max? You can now toggle navigation presets to match your modeling software. This allows you to rely on existing muscle memory, making the learning curve significantly smoother.
6. Beyond Static Renders: A Unified Interactive Workflow
Design storytelling doesn’t end with a still image. With D5 Render 3.0, we’ve integrated our advanced presentation tools directly into the core interface, putting high-end delivery workflows in the hands of every user.
Interactive Tour Suite
Whether you need a quick panorama or a hyper-realistic walkthrough, D5 now offers flexible ways to communicate space via the web:
  • BonjourPanorama Tour: Speed is key. Instantly turn 360° panoramas into shareable links—perfect for quick client updates.Bonjour
  • Spatial Tour: Curate the journey. By integrating floor plans and setting specific waypoints, you can guide viewers through a structured narrative with clear spatial context.
  • Visite XR: Experience the cutting edge. Powered by Étalement de Gaussienne 3D, this feature transforms scenes into high-fidelity 3D spaces. We’ve optimized the technology for sharper visuals and fluid performance, allowing clients to freely explore the space in their browser. You can also bring 3D scanned projects directly into your scenes with experimental support for .ply and .gs files.
XR Tour à D5 Render: Rapid transformation of scenes into high-fidelity immersive spaces
A lire également :
What is XR? How D5’s XR Technology Transforms Architecture?
Comment utiliser le rendu gaussien pour convertir des vidéos MP4 en modèles 3D
Real-World Context with Cesium
Forget modeling surrounding city blocks from scratch. With the Intégration du césium now accessible to everyone, you can load precise 3D geospatial data to instantly ground your project in its actual urban environment.
Cesium in D5 Render: Instantly ground projects within real-world urban contexts
A lire également : Comment utiliser le césium dans D5 Render 2.11 pour la cartographie 3D (3 étapes)
Refined Management Hub
We’ve streamlined your workspace. Myspace now houses Showreel within the sidebar, creating a single, intuitive hub for managing your profile and editing tour projects without breaking your flow.
More Feature Highlights
These are just some of the highlights of D5 Render 3.0. This update also brings a resizable sidebar, HDRI resolution control, CMYK texture support, and more. Take a look at the release notes to get more details on all the updates.
Elevate Your 3D Design Workflow Today
D5 Render 3.0 goes beyond adding features—it unifies your fragmented 3D design workflow. As the intelligent core of our All-in-One ecosystem, this release empowers you to transform your creative intent into professional visualizations in real-time. Download D5 Render 3.0 today and step into the flow.
FAQs on Optimizing Your Design Workflow with D5 Render 3.0
Q1. How can I speed up my architectural design workflow and reduce software switching?
To eliminate the friction of managing multiple tools, the New D5 Workflow offers a fully connected ecosystem. It creates a seamless ‘Flow State’ by uniting D5 Lite for concept exploration, D5 Works for curated resources, and D5 Render 3.0 for high-end visualization. With 15+ built-in AI features acting as the intelligent core, this all-in-one integration ensures your creative momentum stays uninterrupted from concept to final render.
Q2. What are the best real-time rendering tools with built-in AI features in 2026?
D5 Render 3.0 sets a new benchmark by embedding AI as the intelligent core of its workflow, rather than treating it as a plugin or add-on. The latest release introduces a comprehensive suite of generative tools, such as AI Image to 3D and AI Scene Match. By combining real-time concept exploration (via D5 Lite) with high-end visualization, D5 stands out as the top choice for architects seeking a cohesive, AI-powered ecosystem.
Q3. Where can I find a rendering workflow that integrates high-quality AEC assets?
You can find this directly within Lanceur D5 through the new D5 Works integration. Acting as a premier creative hub, it connects you to a vast marketplace of curated, professional-grade assets without leaving the launcher. By centralizing resource management, D5 Works removes the friction of hunting for scattered files, allowing you to maintain a fluid, uninterrupted design workflow.
Q4. Is there an AI tool that sets up rendering lighting based on a text description?
Oui, D5 Render 3.0 makes this effortless with its AI Scene Match agent. Instead of manual adjustments, you simply type a prompt describing your desired atmosphere—such as “Autumn dusk” or “Snowy winter.” The AI generates reference visuals and instantly applies the corresponding lighting and post-processing parameters to your scene. This eliminates hours of trial and error, delivering professional-grade environmental lighting in seconds.
Q5. Can I generate 3D models directly from reference images?
Absolument. D5 Render 3.0 introduces a powerful AI Image to 3D tool for exactly this need. If you require a specific furniture piece or decoration not found in the library, simply upload a reference photo. The AI will analyze it and generate a high-quality 3D model in seconds, ensuring your design vision is never limited by a lack of assets.
Q6. How are technologies like 3D Gaussian Splatting being used in architectural visualization?
Gaussian Splatting is revolutionizing how we visualize real-world site contexts. D5 Render 3.0 has integrated native support for this technology, allowing you to import .ply and .gs files directly. This enables architects to bring 3D-scanned environments into their renders with significantly sharper visuals and smoother performance than traditional photogrammetry, effectively bridging the gap between physical reality and digital design.
Vous pourriez aussi aimer
Contactez nous
