D5 Render for Revit | Real-Time Rendering Workflow
Connect Revit and D5 Render with D5 Sync, to achieve photo-realistic rendering in real time.
*D5 Sync supports Revit 2018.3 to Revit 2026.
D5 Sync is a live sync plugin to link Revit and D5. To run it, please install D5 Render first.
Why choose D5 Render for Revit
Live Link for Instant Feedback
D5 Sync for Revit offers seamless real-time sync between Revit & D5 Render. Instantly update geometry, materials, & cameras – no manual export/import needed! Enjoy full visual fidelity & a fluid workflow from concept to photorealistic render.
BIM data retention and structure
D5 Render preserves Revit element hierarchy & metadata during import, enabling efficient categorization of walls, windows, and furniture for faster scene setup and selective rendering.
Access to a Massive Asset Library
D5 Render provides instant access to a massive 16,000+ asset library (trees, furniture, etc.). Effortlessly drag-and-drop to enrich your scenes within D5. Streamline asset integration for faster, intuitive visualization.
AI-Powered Tools for Creativity and Productivity
D5 Render integrates AI tools like Style Transfer & Inpainting. This streamlines workflows, maintains visual consistency, and lets you focus on design while D5 intelligently enhances scenes for smarter, efficient rendering.
Fast & High-Quality Rendering
D5 Render leverages GPU rendering for fast, high-quality visuals on complex models. Supports real-time client presentations, faster design iterations & decisions with full fidelity.
FAQ
Why Are Textures Clearer Up Close Than Far Away in D5 Render When Using D5 Sync for Revit?
Reason: Select the ‘NVIDIA Control Panel-3D Settings-Use the advanced 3D image settings’, which may make modeling software/D5 show blurred textures in the farther areas.
Solution: The correct setting is select the ‘Let the 3D application decide’ instead of ‘NVIDIA Control Panel-3D Settings-Use the advanced 3D image settings’.
💟 Please let us know if you would like to receive remote support. Conntact support@d5techs.com between Monday to Friday, 10:00 to 18:00 (GMT +8), we are available for remote support.
🔔 Still Need Help? D5 Forum, Help Center, D5 Facebook group
Why Does D5 Sync for Revit Show the 'Could not Reach Server (Timeout)' Error?
This error is usually caused by interface conflicts.
Suggestion: Please restart the device and connect with D5 again.
Why Does the Model Orientation Appear Different in D5's Top View After Syncing With D5 Sync for Revit?
Reason: D5 uses Left-handed coordinate system while some other software use a right-handed coordinate system, so there will be discrepancies between them.
Solution: It is suggested to use the D5 Sync plugin to sync the top view perspective in modeling software. This can make the top view effect be consistent with that in the modeling software.
Why Does D5 Sync for Revit Show 'Rendering Not Supported/Disabled' Prompts in Revit?
Reason: Material Library is not installed correctly.
Solution: Uninstall and reinstall Autodesk Material Library.
Why Are the Relevant Parameters in the D5 Sync for Revit Settings Grayed Out?
Please check whether you are currently using D5 Sync for Revit for linkage operation. Generally, it does not support the modification of relevant parameters during linking, so the display is grayed out. After linking, you can adjust the relevant parameters normally.
